Hello,
I’m sorry but I don’t speak English!
I have install Wled and it works perfectly…congratulations!
So I installed WLED SR and encountered 2 problems.
when it’s on and there’s music (audio line in), it works fine but not always. If I turn the power supply off and on again, the effects work but the sound effects don’t work. It seems that the music signal is no longer being processed. i’ve used Default pins.
Is this a bug? When I turn on the power supply, all the LEDs remain in orange color, then if I select an effect, it works normally (or it doesn’t work as in point 1). Is it possible to turn on the power supply and the ESP32 works with the previous effect?. I mean, is it possible that the effects start automatically? The main problem is that it is boring to activate the effects with the smartphone every time. It would be better if it worked automatically and changed the game of light following the favorites.
Is there a solution to my problems?
ESP32 DevKit.
Thank you
