ESP32 board with good install. When I connect and go into effects the only one that works is solid. I can change colors with no problem but when I try to change the effect to work with the mike all LEDS turn off. I’m using a MAX4466 connected to D35, an ESP32WROOM , output to LEDS on D2.
While MAX4466 is not the best mic , it still worked . First try to usb install ( No OTA ) SR13.3
from here and use gpio36 or gpio39 for the mic https://wled-install.github.io/
Thanks, that got me going. I appreciate the time you took.
