Using Weld in ESP32 Devkit v4
Hello friends, I have 32 LED branches, each with 32 LEDs. I want to set up LED kits with a wled and an ESP32dv kit v4 board, but this board gives me 16 pins. I want a solution to solve this problem.?
daisy chain the data signals or use two boards. if you want to display the same on several branches, you can use data splitters.
