Currently it seems that many effect options (e.g. SEGMENT.check1, …) are not sent/received with UDP Sync. Issue #3487 ‘Not all segment options are synced using UDP’ confirms this, but doesn’t explain why.
Is there any reason not to increase the message size and include the missing effect settings? Is there a preferred sync method that has better coverage of the data?
