Hi, I’m having an issue with my wiring; I have a diagram below of exactly my wiring, because the WT32-ETH01 does not always boot correctly and connect to wifi every time, I introduced a delay relay to delay the boot so it would successfully connect each time. Because of that, I think I now have an issue with my logic-level converter.
For simplicity’s sake, here is the hardware used:
- 3.3v to 5v Logic Level Converter Module
- NE555 DC Delay Relay (5v version)
- DC to DC 12v to 5v Step Down Converter Module (5v, 3a output)
- WT32-ETH01
- Wago Connectors
- 12v Power Supply
I have done the following to help:
- 12v is going to the converter, and 5v is coming out of the converter (tested).
- 3v is being sent from the WT32-ETH01 to the logic level converter, and 5v is being received on the other side.
- The delay relay has power immediately when powered on, and the WT32-ETH01 gets power successfully when the timer goes off.
The issue is, it never shows on WiFi or on the network at all, if I plug in ethernet, the ethernet lights never turn on (interesting).
Keep in mind, remove the logic level converter, remove the delay relay, the WT32-ETH01 appears perfectly fine, it also works if I connect just the logic level converter without the delay relay, but only if I disconnect the 5v cable and reconnect it (as if the converter needed power first?)
Things to note:
- My LEDs are 12v but require 5v data (So I’ve been told)
- The maximum output of the WT32-ETH01 is 3.3v, hence, the logic level converter.
- The 5v powers the WT32-ETH01, despite it being able to be powered by 3.3v because it was easier than converting again from 5 to 3.3 then back to 5.
I have tested every combination of cable going to and from, I’ve tried just the logic level converter on the delay relay, I’ve tried just the WT32 on the relay and not the logic level shifter. I feel I’ve tried everything.
I believe the issue is the logic level converter though, somehow, it wants power before the WT32, because without the delay relay, but without the relay, the WT32 doesn’t connect to the network.
It’s weird how the ethernet lights don’t power on though using the relay delay, but do if I remove it. Yet, 5v is being recieved at the WT32 successfully.
I am in desperate need of help, I am not kidding when I say this, I started this on January 1 and have spent over 80 hours on just this for me to finally accept I failed and that I need help. Typical guy.
Please someone help me, I realise it might take you considerable time to look at it and assess my mistake, which is why I didn’t want to ask because I don’t want to bother anyone, but I really really need help.
