I have been working on this project on and off for the last year and it is finally complete! It is a 3D printed model of Spaceship Earth at EPCOT. I modified the model to hollow it out and cut 1.8mm holes to replicate the Points of Light display that happens on the real building. I then glued in 1922 addressable LEDs that are controlled by an ESP32 WROOM board running WLED .16.
I also recreated 2 of the nighttime shows that take place on Spaceship Earth using dozens of presets and timing them out in a playlist to closely match the Points of Light show on the real Spaceship Earth.
Stats
1924 LEDs (1922 in the sphere, 2 in the sign)
Size: 10βh x 11βw x 11.5βd
Pixel Diameter: 1.8mm
~65 hours to build
34+ hours just to install the lights (drill out hole, insert light diffuser, glue LED in place x 1922 LEDs)
140 hours to 3D Printing
8 printed pieces
15 LED strings
175β of wire
4.5 amps / 22.5 watts
~$400 in materials
Built in temp sensor cuts power of it gets too hot inside.
Custom build of the WLED software
40th show consists of 35 scenes
Timeline
March 13th 2025, project started. Confirmed WLED software & hardware could run this many LEDs
March 27th started work on the model by hollowing out and cutting holes in an existing 3D model of Spaceship Earth
August 2025, used ChatGPT to determine the number of holes. Learned a new shape, Pentakis Dodecahedron
September 2025, model completed and printed as well as 2000 light diffusers to go in the holes
October 2025, started programming the controller and mapping out the LEDs. Came across a limitation on mapping so many lights.
November 2025, @blazoncek made me a custom build of WLED to fix the LED mapping issue.
December 2025, did all the electrical work soldering together all the LED strips and started installing the LEDs.
February 2026, finished installing the LEDs and began the Test and Adjust phase. Redid all the electronics to fix a flickering issue with the help of @Jinx @saratoga @divsys
March 2026, hardware phase is complete, sealed the sphere shut.
Original model: itim77
https://www.thingiverse.com/thing:4073521
WLED Fixes & Custom Build: @blazoncek
