Logger: homeassistant
Source: components/wled/binary_sensor.py:59
First occurred: 8:36:48 PM (773 occurrences)
Last logged: 10:46:56 PM
Error doing job: Task exception was never retrieved
Traceback (most recent call last):
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 137, in _handle_refresh_interval
await self._async_refresh(log_failures=True, scheduled=True)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 270, in _async_refresh
update_callback()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 330, in _handle_coordinator_update
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 533, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 571, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 539, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/binary_sensor/__init__.py", line 209, in state
if (is_on := self.is_on) is None:
File "/usr/src/homeassistant/homeassistant/components/wled/binary_sensor.py", line 59, in is_on
and beta > current
File "/usr/local/lib/python3.9/site-packages/awesomeversion/awesomeversion.py", line 164, in __gt__
return self.string != compareto.string and self._compare_versions(
File "/usr/local/lib/python3.9/site-packages/awesomeversion/awesomeversion.py", line 201, in _compare_versions
result = handler(AwesomeVersion(version_a), AwesomeVersion(version_b))
File "/usr/local/lib/python3.9/site-packages/awesomeversion/comparehandlers/modifier.py", line 28, in compare_handler_semver_modifier
SEMVER_MODIFIER_MAP[version_a.modifier_type]
KeyError: 'b'
Seen this error in HA many times now. How to fix it?
