WLED not working?
Hi everyone, I am a complete noob and just trying to make something for a trip. I am using a Wemos D1 mini pro v3 chip. I think this could be a manufacturer problem but wanted to ask here to see if theres advice to fix a problem I am having.
I initially ordered 2 wemos chips, plugged them in, installed WLED, connected to wifi and app, disconnect from the computer, then solder leds to it and the lights turned on and worked with no issues, immediately turned on and was working.
I also had a second pair of the wemos chips from a separate order and ran through the same thing, plugged it into the computer, installed WLED, got connected to wifi and app, disconnected from computer, soldered leds. But when I turn the board on, nothing happens, the lights don’t turn on, I can’t find nor connect to it in the app. If I try connecting the chip to a computer to try reinstalling WLED, it gets stuck on “preparing installation” and it can run like that for hours.
I assumed the two from the second order were broken and ordered another pair, and I got the same result, they didn’t work.
Does anyone have an idea of what the problem could be and how to fix it?
Try installing from here and see if it works: https://wled-install.github.io/
