WS2811 COB 24V, 2023 strip works but 2024 strips wont
From your pic, I don’t see an “open GND on the top right…”.
There is one directly opposite (lower right) the ground you’re using and yes they should be connected internally on the board. You should be able to use either.
As far as power supply connections, I would suggest that you connect your PS DC grounds together on the supplies not on the ESP32. You can use a separate data wire with accompanying ground wire connecting to the levelshifter and then your LEDs.
As mentioned before, clean simple wiring of the 74AHCTxxx is important.
Using the bypass cap and neatness both count. The resistor is the last thing I would worry about.
Thank you for the reply.
I did indeed mean the ground on the oposite direction, my bad.
Will wire the PS DC grounds togheter.
I use a piece of board to solder the feet for the 74AHCT and connect wires on the back:
Applied hotgleu and crimping. Orange wire is solderd to GPIO
More pics will follow.
Overall, that’s the right idea for the 74AHCT125 but some notes:
  1. The bypass capacitor must be on the perfboard as close to the power pins as possible.
    Normally you place it “above” the chip so that one pin is right next to Vcc (pin 14 on the chip). Solder that up and then use a short piece of wire to bridge to the nearest grounded pin (in your case pin 1 is grounded so that’s convenient).
  2. Best practice is to use a single 5V and a single Gnd connection to the board. Jumpers of Gnd and power between the pins are done with (very) short links. Unneeded long wires are not your friend. Remember, these are data connections and don’t require any (appreciable) power handling. You can use very tiny (24AWG or smaller) wires.
    I mentioned the alternate wiring diagram as it uses Gnd connections for all the unused inputs rather than +5V and Gnd. It will work properly with the '125’s and I find it easier to wire on perfboard. As well, if you end up using multiple GPIOs (and even if you don’t), that diagram shows how you can use provide more than one data line to your LEDs.
    Driving each strip from its own data line rather than tying them all together is a much better practice. You can still tie all the levelshifter inputs together so they appear the same.
I would get rid of that yellow dupont wire and use something a little heavier. I could easily see having a bad solder connection when using that as there is very little wire in those to make good contact with.
Good point Jinx, I used what i had.
Now have true copper wire 0,25mm²
Will solder new board tomorrow using coper only.
Divsys thanks for another reply!
Will place capacitor over pins 1 and 14 on the new board
Also found out my 5V convertor board (no potmeter to be found) outputs 5,2V might be an issue?
You mentioned the alternate wiring diagram but i’m not sure what diagram you are referring to.
You suggest not Connecting power on the unused xOE port?
Then which of the unused ports should i ground?
xOE
xA
xY
Will make new board with beter and short jump wires.
Will post, thanks for your help.
If this project comes to life my ceiling will consist of 1620 5cm “neon” leds, can’t wait to experience that. Since there are that many light sources i’m expecting little to no shadows which must look special “studio” like in your own living room.
On the KB Levelshifter page, there’s a section “How to connect Levelshifters”.
The first diagram is labelled as 74AHCT32, but it will work exactly as shown for 74AHCT125’s as well.
The only unused pins you need to worry about are the xOE’s and xA’s. The xY’s are outputs and can be left alone.
You’ll note that diagram also indicates how you can use more than 1 channel for driving LEDS.
As I mentioned, you may be better off in the end by using 1 channel to drive each strip and connect all the channel inputs to the same GPIO (or 4 separate GPIOs).
I have this exact same black strip. I am having zero luck getting it to work. Also bought the 74HCT125 for level shifter. Using an EPS32 WROOM. I’m about ready to give up on these strips. What is a reliable strip of LEDs I should use instead?
Hi folks, have the exact same strip, almost driving me crazy because I couldnt get it work and just found this topic
here is the exact model I’m using https://pt.aliexpress.com/item/1005004770570289.html?spm=a2g0o.order_list.order_list_main.59.1439caa4OXmXzH&gatewayAdapt=glo2bra
It goes from flikering to unstable colors and everything else
Your link is dead.
My project is on hold, but i feel confidend that I will be able to fix this using the level shifters.
Are you using level shifter? if not, there is your first problem.
hey @Jackel sorry about the dead link it might work by removing the query params: https://pt.aliexpress.com/item/1005004770570289.html
in any case I’m using a 24V COB WS2811 from coolean brand.
About the level shifter, do you have any specific one that recommend?
@divsys linked to them farther up in the topic replies.
Been busy, project is on hold.
Did find one other thing;
BTF has a signal aplifier, which I have succesfully used to level shift for my strip.
It’s affordable and just works.
I’m now looking into ESP32 out of the box on 24V.
ESP32-WROOM has some interesting options.
Would love to find a board that accepts 24V and has build in level shifter, tips are welcome.
These will all take 24v:
@Jackel just curious did you ever get back to this project? I’ve just jumped onto the LED train and slowly learning about all the issues with WS2811 BTF lighting strips. I ordered the 24V white PCB version off Amazon in 2024 and I only got it connected to an ESP32/WLED for the first time. Everything works perfectly if I have a very short data line, keeping the ESP32 close to the LED strip… but I do want a slightly longer data line for my installation and I have ordered a pack of SN74AHCT125N. Before going down the rabbit hole, did you have anything to share from your trials or did you get that far?
The project is still on hold but will be picked up in the future.
I have one simple led strip above my table as main light.
Used a levelshifter and wago’s for connections.
There is very little flicker. removing the levelshifter reverts to the old flickering pattern.
The last bit of my issue’s is in my grounding connections. you should solder all, good luck!
Keep us posted on your findings please.
Hi. I dofent know this IC 24v had so much problems
I try to get my to work with out of luck. And finding this thread.
Why are you using a resistor in data?
I bet this is the solution to mostly of the problems.
Thank you for sharing this information.
For me the project is still on hold, but I will pick it up in the future.
I would like to add this as info; it’s about signal interference on the data line.
