I am using 4 strips of ws2812 on a dig quad. Each strip has a different amount of leds (40, 60, 80, 100)
In the setup I checked the box that says “Make a segment for each output”
After saving each strip showed up as a different segements each segment is showing the correct pixel count. So far so good.
What I am trying to do is have each segment with a different preset. Then I want each preset to come on at a certain time of the day. I understand how the time & macro work (using them on another project with a single strip).
I am having a hard time setting the segments and presets.
What is happening is that I check the tick box on the segment I want. I create the preset and save it.
I then uncheck the box and do the same procedure for the second segment, and so on.
I then created the time base portion, but what happens at the instance of the first firing (does so appropriately) all the lights come on.
I have also noted that if I look at the code on each preset it includes all the segment.
I am missing something critical.
Can someone point me to a video/tutorial that would help me figure this out.
Thnaks so much.
