I want to be able to clear the existing effect when invoking an alexa command. Even if I have to tell it to turn the lights off and then back on.
As it is, if an animation plays, voice commands don’t stop it. I can change brightness and color and toggle power but none of those will reset the effect.
I thought the alexa on/off macros would do that but I can’t make it happen. If I do a macro of PL=1 it won’t do anything. PL=1 does work if called from the timer. Same thing with FX=0.
I do not wa…
im re-asking here as got stalled in other category…
When I tell Alexa to change color it changes one of the colors in the preset animation running. It doesn’t clear or set the solid color. Is there a way to set something.
I got this in reply, but it says syntax error:
{“tg”:128,“ix”:128,“pal”:0,“sel”:true,“rev”:false,“mi”:false},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
Getting syntax errors in custom json Api command. I tried a couple of things even replacing smart quotes with dumb quotes. any help would be great. t
Hi!
That is not valid JSON. You can try setting {"on":true,"seg":{"fx":0}} as Alexa turn-on preset, which should work
thank you!!! Implementing it now.
