Athom Controller w/ 2 DATA out pins
Using WLED software, I would like to not only use the DATA1 pin but also the DATA2 pin but I don’t know how to do this in the software. Can anyone guide me through this?
Settings/LED Preferences
Scroll down to where your strip is setup on data1 (or whatever is set up). Just under that there is a plus (+) button to add a new strip. Click that. A new section will appear which has all of the settings available that the first strip has, including setting the GPIO pin and LED type, etc.
Great. Do you happen to know what GPIO pins control both DATA 1 and DATA2 terminals?
Sorry, no. I haven’t used an athom controller. I suspect there are some sort of docs for the model you are using?
If this is it: https://www.athom.tech/blank-1/wled-esp32-music-addressable-led-strip-controller
The info is on the bottom of the page
Yeah what came in the box was very sparse and I haven’t found any docs online yet.
DATA2 use(GPIO17)
Did you solve the issue ?
With your help and others I did solve the DATA issue I was having. Thank you.
can you told me how. I will start my projact with around 6 ATHOM
I will conect 10 meter in DATA1 and 10 meter in DATA2.
Yes that seems about right.
