Audip Reactive sync
Good morning,
I have been experimenting with the audio reactive settings, and have experienced some success. These instances operate from Home Assistant, and I am pleased with my automation’s. I have two basic questions:
  1. is it possible to have the slave units persistently default to the AR mode? They way I have been using it, they must be manually set to sync with the AR master I am using the DDP-RGB setting and have sync receive set to transmit on the master, and to receive on the slaves. This will be next years Christmas display, and unfortunately there are power failures from time to time.
  2. There can be a noticeable lag time on some of the slaves, I have 4 ESP32 controllers as such. Would some of the latency be eliminated if I were to run the HA/WLED network on it’s own VLAN or dedicated router?
Thank you and Happy New Year
