Sync some WLEDs with one WLED Sound Reactive
Hey together from germany,
I have a working WLED Sound Reactive strip. Is it possible to sync the sound effect with other WLED?
The normal synronisieurng works - but unfortunately not with the sound effect.
Thanks in advance for your effort.
Finnenzauber
I think they merged DDP support recently so you can set up one as a master and up to 9 as DDP slaves.
You create DDP outputs in LED settings as a “Network DDP” bus.
DDP slaves do not need to be Sound Reactive to work.
Hallo,
If you run srwled on an esp32 then you can have it Audio Sync over udp to other srwled instances in your network , please try the below but only on esp32 . Have fun
thanks for this solution - i am not able to setup SR WLED without mic?! I would like just one master which has mic and others are slaves and uses this. After installation of wled SR and mic is not attached - throws error and nothing happens :frowning:
is somewhere an example how to use DDP ? i did not find any in google?!
https://kno.wled.ge/advanced/ddp/
nice thank you! it works perfect.
