HEy Community,
I’m thinking of havine a wireles WLED Sound-Reactive. To understand it better:
I wanna have on “Master” that is the Sound-Part. It sends the data to a WLED-Client over the WLAN, that reacts to this data. THe Master does not have any LED on it. And the Clients do not have a mic connection. HAs anyone a solution perhaps by hand?
Greets
Sure that is available in wled as part of audio sync , install latest ( with audio usermod ) from here WLED installation (wled-install.github.io)
And in the Audio usermod for the master which has the mic set that to send
And on the Clients set it to receive
Once you are done all the clients ( once you set them to audio effects ) will receive the audio sync from master on that port you specified ( i have changed it but you can keep it at default )
OK. THanks at first ALDIY. But as I thought about it - and from your description - I’d still have a problem: If I have lets say 10 Clients, then I’d have to set the effects on each single one. THats also something I would try to centralize. Any idea?
Sure use sync button on the master and all the clients will switch to that effect
