I know there is code for modifying the NpbWrapper.h file to make RGB 5050 non addressable strips work but I am unsure how to modify and recompile the files. I want to use this on an ESP8266. Could anyone help out with either identifying how to modify the file from the GitHub and making the bin file for the board or providing me a bin file already created?
I’ve built one before for use on a Shelly RGBW2. The LED pins are…
#define RPIN 12 //R pin for analog LED strip
#define GPIN 15 //G pin for analog LED strip
#define BPIN 14 //B pin for analog LED strip
#define WPIN 4 //W pin for analog LED strip (W1: 14, W2: 04)
Sure it does… I have a bunch of them running espeasy and doing all kinds of things around the house… There is the regular gpio 0 2 then there is tx gpio 1 and rx is gpio 3… I have a bored i made with 4 mosfets on it and a esp8266-01 that has been running a rgb strip of about 30 leds and a white strip with about the same amount of lights for a few years. I have also built a autostart bored for my car with a esp8266-01 i love these little things!
Wow your awesome! This is the first time i have ever posted anything or ever really even said anything to anyone on line! It doesn’t matter the order lets just try and avoid gpio 0 lol… It would be even better if you could help me figure out why i cant build the bin myself… I want to try a bunch of different things…
Strip the paths down to make it readable, and post your error messages. Those error messages are butt-ugly with the prepended paths…
The error messages will usually help you figure out what went all pear-shaped in the compile, though I have to resort to a google search on occasion with weird errors.
edit: I just downloaded WLED and required libraries and built it here (Arduino 1.8.10, esp8266 git repo) and although it had an IMPRESSIVE number of warnings, it built and runs OK. I had to manually install me-no-dev’s two libraries from git as they don’t show up in the Arduino library manager.
Yes it is I’m almost expert at creating bin’s now ive been trying to figure out how to out put to more then one pin i have 7 esp’s in one room! im also trying to figure out turn off the analog strip when I’m using hyperion then re enable… I see you all over this place tonyno lol and you know your shit… point me in the right direction homie…
Hi Dave, would you mind making a bin file for me. I am using the magic home RGB controller for RGB strip. Looking at the tasmota template https://templates.blakadder.com/arilux_LC01.html which I have working succesfully, it looks like the pins are 5,12 & 13. I am not sure which pin is for the RG or B but from what I see you can change the assignment in the app ?
I read the thread and it is still not clear to me if it is possible that led 5050 + esp8266 + wled works
does this file work? wled00.ino.generic.zip 310.9 (KB)
I tried to record it in esp8266 but I can’t get canexion with wled
I hope someone can help
Cheers
(really newbie)
