Can a button cycle through playlists or just presets?
https://kno.wled.ge/features/macros/
Is a little unclear to me.
They’re all the same thing, you just refer to the number of the playlist/preset and it’s internal definition tells WLED how to process the contents.
Or to put it another way, a preset is just a simplified playlist of only 1 item with default transition info.
A playlist is the more general version of “n” presets listed in order with defined transitions.
You’ll note you can’t have a preset #7 AND a playlist #7 (or any other number).
Is there an example available for a button to cycle through playlists?
I have a button that when I long press, would like to cycle through playlists 100-105. I created a preset with API Command: P1=100&P2=105&PL=~ and assigned it in the macros section. When I select the preset or press the button, it selects Playlist 100, but when press again will not cycle to Playlist 101. It just keeps selecting Playlist 100.
Have you tried something like the first two rows
This was the bug that chatted about in discord and that I submitted to MM. It still exists in the xx27.31 release, but has been fixed in their dev builds. Thank for your help on this one!
