Anyone know of a way to do this? Other than modifying the source code and recompiling it??
Have checked similar topics but nothing really helpful.
Effect: Chase 2
Set colors 1 & 2
Candy Cane was removed in 0.13.
Thanks but not exactly the same as Candy Cane
Running version 13.3 (Toki)
Candy Came seems alive and well to me.
Thanks though.
Then it is 0.14. I do not keep track.
Then Running 2 with red and white.
don’t understand what you are trying to tell me. Explain in more detail please??
Running 2 is the effect that you use. Red and white are the primary and secondary colors you set to make a candy-cane effect. ![]()
There’s an effect under V0.14 that’s called “Chase 2” which can be used to get the effect Candy Cane used to give you.
You’ll have to play with the selected palette, foreground and background colours, as well as speed and intensity.
I feel stupid but could not find .014 on github. Where to DL??
Threw a JSON syntax for me. Is this for .14 or .3.3
Here is a collection of pre-compiled .bin’s WLED-wemos-shield/resources/experimental/Firmware at master · srg74/WLED-wemos-shield · GitHub
Well got .14 flashed and started tinkering. Interesting to say the least. I am using Chase 3 and created 2 presets (both red AND green). I’m also going to try Running 2 per tonyno.
Play lists don’t seem to work at all (for me). Anyone gotten playlists to work??
Thanks to ALL who have been so helpful to me with this issue.
