I’m trying to use an old IR remote I have with WLED.
I have got the raw codes from the remote using an Arduino:
Protocol=NEC Address=0xC031 Command=0x87 Raw-Data=0x7887C031 32 bits LSB first
Send with: IrSender.sendNEC(0xC031, 0x87, <numberOfRepeats>);
Protocol=NEC Address=0xC031 Command=0x87 Repeat gap=42100us
By comparing the codes generated for a standard 24 key remote and the official 24 key ir.json ChatGPT gave me a method of converting the raw data to usable codes.
Take the first 3 32 bit ‘words’:
0x78 0x87 0xC0
01111000 10000111 11000000
Reverse the bits:
00011110 11100001 00000011
0x1E 0xE1 0x03
Reverse the order of the ‘words’ to get the final code to enter in ir.json:
0x03E11E
I ‘confirmed’ this method works by comparing the codes received by my arduino for a working standard 24 key IR remote and generating the WLED codes using this method and they matched the ones used in the official 24 key ir.json.
So I applied this method to the target remote I want to use but WLED doesn’t seem to recognise the codes.
Can anyone help me debug this? Could there be something else about the remote I am using that means it won’t work with WLED. I am running WLED on a dig2go controller that is a little broken (some gpio pins aren’t working, am waitng for replacement) but seems to recognise the standard remote just fine.
