I have a gledopto led controller with an ESP32 running wled. It has two outputs wired, pin 2 and pin 16. I have connected a digital led strip to each of these outputs. However, I’m strangely unable to set the type of the first output. I can set the second one to my type (WS2805) but the first one is fixed. If I add one more output, the first and the second one is fixed. Is that normal?
yes, its currently that way, set it up in order.
Okay so how do I set the first one? It starts with two, and I cannot remove the second to set the first.
you can remove the seconds with the “-” button. unless that is some special version of WLED
Try to reflash your controller.
Some time ago, in my case, it was unable to change B & W and store for WS2814 chip. After save, B & W was not changed in settings.
