Hardware setup > LED 1 drop down deactivated /greyed out / grayed out
I installed WLED_0.15.0-b7_ESP32.bin (via
Release WLED Beta Release 0.15.0-b7 · Aircoookie/WLED · GitHub ) on a GLEDOPTO GL-C-010WL-D.
Now for the first LED strip (LED 1) I cannot change the LED type; the drop down box is deactivated / greyed out.
What could be the reason for this? The drop-down worked before with stable version 0.14.4 (which was preflashed on the GLEDOPTO device), my intention to use the beta release are to make WLED work with a WS2805 12 Volt 1 Meter strip (BTF-12V-060L-B)
Yes that is the current behavior ( right or wrong I cant say ) .
To fix this you need to delete the 2nd output and then you will be able change the 1st output
