I also tried to go in devices manager and update my driver but having troubles doing that
Not sure what do you mean you have trouble updating your driver , show devices manager and the error . Meantime close all windows and apps and try from this site WLED installation (wled-install.github.io) and if you still having issue then reboot your pc and try again .And I assume you have usb data cable and not only power
Reboot your pc after installing the driver(s). Also make sure you are using a usb cable that supports data transmission.
Okay so i go to install.wled.me and then install the silicone bay driver. Still no devices found. I reset my computer im not sure if i have to update my drivers in my computer settings for it to use them or what. Also how can i tell if im using a data transfer cable
Omg i used a different cable and it worked
Woww thanks so much guys i should have known
Could one of you guys help me with AP mode
Should i enter any wifi settings if i want to use AP mode
AP mode is default. No settings needed.
