I have built a couple of WLED projects and have mostly accomplished what I want to do… But there is one issue I cannot figure out. With some builds, I get constant reboots.
Because I am lazy, and I like the add-ons, I am installing the Moon Mods versions from https://wled-install.github.io/.
Here are the offered builds.
If I install a build that says “fixes reboot issue” then the board works fine. If I try the other versions… It reboots every few minutes. So, I don’t think it is my hardware setup, and there appears to be a known issue as that fix is listed in the notes.
So my question is “how can I get a build with tons of mods like Animartrix and audio reactive that is stable?”
There are so many builds out there it’s hard to figure out what to use.
I have been using this site simply because the web flasher is so convenient… I am open to other options.
(My unfulfilled goal is to get a build that has some kind of support for animated gifs along with Moon Mods and audio reactive features.)
Thanks if you have any ideas.
