Hello!
1st time I decided to try the MoonModules version on ESP32/ Installed version “WLEDMM_0.14.0-b29.35_universal_shield_esp32_4MB_M.bin”. Everything installed fine.
The question is: What do I need to do so that effects from the page Effects - WLED MoonModules Project appear in the list of effects in the WEB interface? I’m asking about effects numbered 142,151,161,169,170,171,188 - 229, marked with the “Y💡” icon. There are currently only 7 effects in the interface with the “▦” icon. Is this how it should be?
What am I doing wrong? Should these effects appear in the interface list with this firmware?
Thanks for the answer. I’m going to try now. I didn’t think to turn on the “2D” mode myself. Do I understand correctly that “reboot your module” means pressing the button on the “ESP32” module? Or some other way?
Yeah it is okay , the one on the left is the mini peek same as if you press on GFX button
or if you type your unit http://wled-ip/liveview2D
The one to the right is for ledmaps and will show you the virtual pixels location if you used custom ledmap
Thank you very much for your help.
I want to play with this too but I can’t actually find the bin file you named.
Is there a web flash tool for the MoonModules version?
WLED installation (wled-install.github.io) look at the bottom of the drop down list
Edit to add: figured it out. The XL builds do not have Animartrix. I found it here:
Thanks! But…
A couple of days ago I had actually already found that site and installed that exact build, and I have a 2d matrix configured… but the Animartrix usermod is not visible.
I just reinstalled and set up the matrix again… Rebooted the device and I cannot see Animartrix anywhere in the config.
Under info I see:
Under /settings/um this is the list of usermods:
Have I missed a setup step to reveal Animartrix or do I need a different bin?
Might be the XL builds is busted , try the M build which is tested above
As far as I know, the XL version requires an ESP32 with 16 mb memory. I installed the version with the letter “M”.
Thanks!
(I was able to install the XL build on my 4 MB device.
@ALDIY the M build has what I wanted, thanks.
I am all set now.
