Hello everyone and thanks a lot at aircoookie for that awesome project : )
I want to set lights for my fish tanks with each:
Three pwm stripes (warm white, cold white, rgb),
H801 Led Controller (esp)
and Homeassistant
My problem:
The fist tank is fully equipped now, but I have the problem, that the brightness is only around 70% at maximum. (i measured around 9 Volt at the white channels)
I will post my settings below, maybe anyone knows what I am doing wrong.
Thanks so much.
Hi akriss, I guess you are right, I will change the cable and look if it’s working.
I am using old network wire (kind if thin, don’t know the gauge) it about 1 meter long.
I’ll let you know.
The Power supply is an 12 Volt 10 ampere device. (LED have 50 watt max).
The Rgb channel showing 12 Volt.
Should I try shorter cable? 1 meter Should be OK…?
Remember analog LEDs are not wired the same as addressables are. The LEDs drop voltage as well, that’s how they give off light.
Depending on where/how you’re doing your measurements, you may see the powr supply minus the LED drops.
Try each RGB channel individually at 100% and see what voltages you get.
You could also try to bypass the controller completely and just ground one channel at a time to see what’s the maximum possible.
You may find the voltages you think are “Low” are just the most you will ever see.
I put them directly on the solding points on the stripes.
And yes, also when I use the stripe without controller. Just a small drop of max 0,5 V in both cases.
And when I use the wled front-end to rise the brightness, I can see, that arround 160 it is not getting brighter…
