Anybody know if i can make wled talk to these:
Haven’t done it myself, but specific mention is made in the underlying NeoPixelbus library.
P9813 is one of the LED types you can select under Config->LED Preferences->LED Outputs as well so it looks very good.
The P9813 requires two pins, one for CLK and another for Data.
It is a 5V device so you’ll very likely need a separate Level Shifter for each of those pins.
Edit - A little search on the forum turned up :digital-addressable-analog, (you might not even need the level shifters if the distances are short)
Thankyou for helping me with this. I’ll let you know how it Goes
