ESP32 Board with 2xLAN
does anybody knows how to get an esp32 board with 2xLAN? I would like to use WLED with LAN connection, but i need the LAN port also for different things. I want to avoid a dedicated minihub or use Y-kabels to split up the line.
thanks,
Tom
Please more information (more specific)
Never seen one, but why could you not use the same connection? It’s not like you can run 2 firmwares on the same board at the same time anyway.
That’s not how physical ethernet connections work.
You need a hub or a switch port for every physical connection to your network.
The “dual port LAN” version ESP32 you’re looking for would just be a board with a 2-port switch built-in.
Either use WiFi or put in a switch, honestly an 8 port gigabit switch is what - $25 now?
That’s just the cost of expanding your network.
