My ESP32 with WLED 0.14.0-b1 turns it self off (and on) randomly. After toggling the power button in the UI, typically after 30-60s the system turns the LED strip off by it self. The UI is still active and under Info the up-time shows that there hasn’t been a reboot or something. I hope to find some help here.
I managed to upload adebug version of WLED 0.14, which gave me the following data. The first " Sending WS data" is me giving the ON input via the webfront end. The last " Sending WS data" came out of now where and is probably the bit that is ruining my WLED experience:
Wifi state: 3
State time: 0
NTP last sync: 999000000
Client IP: 192.168.0.100
Loops/sec: 2285
UM time[ms]: 0/1
Strip time[ms]: 0/1
Segments: 2 → 288B
Modes: 4187=748B
Data: 4187=748B
Map: 2*0=0B
JSON buffer locked. (11)JSON buffer released. (11)
JSON buffer locked. (12)
JSON buffer size: 2076 for WS request (1150).
heap 197892Sending WS data to a single client.
JSON buffer released. (12)
heap 197736Sending WS data to multiple clients.
Local time: 19:41
Not-Found HTTP call:URI: /presets.json
WS FileRead: /presets.json
JSON buffer locked. (17)
JSON buffer size: 2075 for request: 3
JSON buffer released. (17)Not-Found HTTP call:
URI: /presets.json
JSON buffer released. (17)JSON buffer locked. (14)
JSON buffer released. (14)
JSON buffer size: 793 for request: 1
JSON buffer released. (17)JSON buffer locked. (12)
JSON buffer size: 2076 for WS request (1153).
heap 197312Sending WS data to multiple clients.
—DEBUG INFO—
Runtime: 960419
Unix time: 1684690883,419
Free heap: 199956
- The above is captured from the “naked” ESP32 connected to my PC’s USB port, no addtional power. I get the same behaviour with this board hooked on my QuinLED digi UNO v3, trying two different power sources.
- When the board was on version 0.13.3 (it was delivered like that 3 weeks ago) it showed the same behaviour.
- I have no Macro’s or add-ons installed.
- With or without the power-protection: same behaviour.
