I’m seeing flashes that are kind of random but not totally. It looks like in some cases a “+1 pixel” gets activated.
- Timing seems random
- Color seems to be the color of the previous pixel
- Looks like only one pixel flashes on one pin at the same time (if multiple pixel flash at the same time, then they are on different pins)
- Best seen at edges between light and dark areas
- Best seen with static patterns
Here is one taken from a slowmo video:
I’m using
- esp32 dev kit
- around 3.000 LEDs
- 6 pins - each of them powering one column
- 200w power supply with multiple power injections
- logic level shifter for each of the 6 strips/pins
- 40 LEDs are grouped for each square
I’m seeing this effect with wled 0.14-b1 and 0.14-b4.
Do you have any ideas what could be the reason?
