Does shorting GPIO0 to ground on a ESP32 still cause access point to start?
Will this still happen if the ESP32 is currently connected to a network? I couldn’t get my devices to work this way.
GPIO0 to ground for >6 seconds will reset the Wifi config.
IS it OK to leave GPIO0 floating?
Yes as it should have a pullup resistor to keep it high with nothing connected.
Most all boards will have the resistor in place already.
I can not get this to work. Is this code still enabled on 0.14.0?
