Help with 1st project
I am planning my first project and need some assistance with it going forward. I would like the middle two to be a group with the same effect, and the other four another group. Do I achieve this through WLED or the way it’s wired? Thanks.
WLED has multi pin support now, so you could connect every string to a different pin. Or connect the middle 4 to 1 pin and use segments.
