Is it possible to automate segment offsets?
So, I made the boneheaded move and hung some 60LED/m SK6812 strips thinking “mOrE lEd BeTtEr”. Welp, I can’t really run that many and turns out, I don’t need to! I found that lighting every third LED is just as good as running all of them. I wrote some custom firmware and had it working pretty well rotating through LEDs to keep the burn time even across the strip.
Now I want more out of my strip. WLED is always my goto for controlling LEDs, but I cannot figure out how to rotate through the strip. Currently, I have a single segment that has a spacing of 3. I noticed there is an offset that will do exactly what I need, but I want to automate it. Here is my question: How can I automate the offset to rotate every n-hours for a given segment?
Thank you ahead of time!
use playlist with clever presets
JSON API is your friend
I tried something along those lines, but making it play nice in HA is a pain. Can I implement this on the ESP32 or will it have to be external?
So I played a bit more with it and your solution checks out. Regarding HA, it seems that it will take some configuring to get a switch to turn on/off with said playlist. I gotta fuse a select and toggle together somehow.
agreed. become a master of segment and playlist control.
segment control has many possibilities
Check my video out. something new to get your teeth into maybe… lol
Jason is a stranger to me lol.
How do I suggest a feature request
