Is it possible to let only every second LED light up?
Hello, everyone,
I am new here and am currently dealing with WLED. That’s a great thing.
Unfortunately, I don’t speak English very well and I use the goole translater to ask my question, I hope that’s ok? Writing in German probably doesn’t make sense, does it?
Actually, I have WLED running with an ESP8266, via MQTT this also works with my in-house automation program.
What would interest me, however, is that you can only use every second LED for some things? So if I want to let the strip shine red, only every second LED should be on.
Is something like that possible and if so how do I have to go about it? can the WLED itself or do you need any other programs / extensions.
I hope someone can help me and is ready to answer me (despite probably very poor English).
Thanks and best regards
Stephan
Look at the Spacing parameter in segment settings.
many thanks for the answer. actually brought me further.
the led strips now shine the way i want them to.
I still have one question. i synchronize two strips with the sync button. the segment does not seem to work, how can you keep two or more strips in sync?
I also have one question about xlights, can you keep several strips in sync and do you have to work with music here? so far i don’t want to do anything with music, but already light up the house without music.
thank you ever for further answers.
Many greetings
stephan
The newly-added vitrual-strip support in the Blaz branch may get you the syncing you want.
