Ledstrip not working properly
Hello,
Im struggling with getting my wled working properly. The setup is a iotorero wled esp32 behind a 150w 12v transformer. The strip is 9 meters long sk6812 12v and put on 12v+data1+gnd but it stop after around 6 meters. I’ve tested the voltage and its around 11.21 volts so that looks good. Could it be a data problem maybe?
If needed i could upload some pictures tomorrow.
check led and segment settings for the right amound of LEDs set. Data problem is unlikely, Could also be a dead LED.
I’ve already tried al kinds of amounts for strip. But thing is it worked properly before when it came out of the plastic but i put a connector between the 2 strips and then it screwed up. And is there a way there a way to test the leds?
take them apart again?
