Does “Make a segment for each output” actually do anything other than confuse me?
I envisioned it automagically making a segment for each of my 4 outputs (ESP32) based on LED counts per output. Not so much?
I also get some “Error loading your preset” messages…
Ideas?
If you already have “non-default” segments set up (and saved in presets) it will not overwrite those.
Remove boot preset and restart ESP it should create segments based on outputs defined.
“Error loading …” usually means your presets became corrupt. You may still recover them by editing them using /edit page.
It seems to overwrite as long as I uncheck, save, recheck, save.
I finally decided it was easier to simply add the segments manually…
Thanks!
Ed
