Matrices on multiple IO pins?
Hi. I’m using 0.15.0-b4. I have 6 LED matrix panels and wanted to split them between two pins at 768 a piece, but as soon as I save the second group, I get errors in the UI and when I look at settings again, the first group has been rendered useless.
Before:
Adding:
After saving:
Broken:
Am I missing something? Looking at this I would at least assume that multiple pins should be possible…
Try either b3 or b5 from Dropbox
b4 has a bug with >300 leds
Thank you @kilrah, but I have a bit of an issue installing anything that is coming from an unofficial site, posted/recommended by someone that is not the product owner. I do appreciate it, but I’ll wait for the official beta release.
You could always find the one you want from Serg’s Repository - pretty well the standard link for all the current versions (if you’re not willing to build your own).
Thank you! I can’t find the binaries to download from that link.
I’d love to, but I am not having luck setting up the environment…
B3 has the same issue.
Try here: https://wled-install.github.io/
That’s my Dropbox and you cannot get more official files than that. :smiley:
But you are educated well to not trust random links. Well done.
Thank you @Jinx
Thank you @blazoncek.
I installed b4 on a fresh esp32 and verified the problem exists. After that I upgraded to b5 from the drop box. After the second pin is added and the config saved, the led preferences indeed remain.
I really would like to thank everyone that has given input.
15.0-B5 did solve the issue. I tried some others, and 15.0-B2 and 14.4 also work with my configuration.
