I’m building a large matrix made up of 28 16x16 panels and while I have a test setup working correctly across 4 ESP32s I’m just wondering if there is a better approach.
I plan to setup a single ESP32 to be the master with 3 more ESP32s setup to be controlled using the DDP RGB (network) option. Each ESP32 will use 4 GPIO outputs to run 2,048 LEDs across 8 panels.
In my testing across 4 ESP32s with one panel per board it worked well but animations do occasionally glitch most likely due to network errors.
I’m just wondering if there is a better way to get 4 ESP32s to talk to each other? I have checked the documentation and this doesn’t seem to be the case. A hard wired solution with no network traffic would be best but I’m pretty sure this isn’t an option in WLED.
