Items used:
- 240v AC to 12v 33.3Amps DC big power supply
- 2811 LED Strip: 12v 5mts with 300 LEDs (60 led / 1.mtr)
- ESP32 - WROOM development board
- 12v to 5v LM2596-NR BUCK converter step down module
I have done everything as mentioned in the following video for my setup: 12v WS2815 with WLED / ESP32 - Setup, Power, Control - YouTube
The only difference in my setup and the video is that in the video a 12v to 5v step down converter is used where as I have used a LM2596-NR BUCK converter to reduce the 12v coming from the big power supply down to 5v and then connected the +ve to VIN connector on ESP32 and -ve to GND connector.
I have connected the green (data) wire from the LED strip to D4 connector of the ESP32 board.
I have used the 0.13.3 WLED installed and installed it on ESP32 board from https://install.wled.me/ using the instructions.
After all this setup is done, I um able to connect to the ESP32 board over wi-fi using the app and changed the GPIO to 4 in the app.
(Screenshot of the app below)
PLEASE HELP… DONT KNOW WHAT ELSE TO DO NOW.
