Need help setting up 2 matrix panels
Hello All, I have 2 matrix panels 76x25 (2 ports) and 23x25 (1 port) and I need your help please. I wanted to set this up so they can be work independently in wled and xlights. Currently it seem like it works perfectly on wled side, I can set 2 different effect on each panel, but not on xlights, Only 1 third of the panel lit up and across both panel. I have search here and discord and reddit but I still couldn’t resolved it. Could you please kindly give me helping hand. Thanks in advance.
Xlights setting
If you are using xLights, set LEDs up in wled as a regular 1d string. You can’t really use xLights and wled in 2d unless you do some very confusing things involving shadow models. *Do not click ‘upload outputs’ in xLights for wled controllers. Just set your pixel counts in wled.
