I have these Rock LED lights for a truck and they are basically dumb RGB lights.
Here is a light example:
I am using the board below with FR1205 MOSFETS
I have the pins correctly inputted into WLED as 15,13,12 and set LED output to PWM RGB per the sketch
https://w.electrodragon.com/w/ESP_LED_Board_HDK
I am measuring the correct voltage on the board and on the actual light itself, but the lights are not on? I can directly hookup up a 5V source to the light and get them to blink. So I know I have the voltage right. What am I doing wrong here?
