I’ve got:
KeeYees ESP8622
WS2812B 60LEDs/m @ 5V (RGB / 3-wire)
Meanwell LRS-100-5 power supply
I’ve tried with WLED 0.12.0 ESP8622.bin and also WLED 0.13.0-b6 ESP8622.bin
I’ve double checked and my wiring is all good
When I power up I get only about one in every six or seven LEDs in no discernable pattern illuminate in greens and blues.
I can connect to WLED via wifi and power the ESP86222 on and off so as far as I can tell the board is working, however I have no control over the LEDs. The same LEDs stay illuminated in the same colours whether or not the ESP8622 is on or off. I can alter settings, presets etc in the GUI but nothing makes any changes to the LEDs.
I ‘think??’ I’ve got the settings close enough to get at least some kind of response. I cut the LED strip down to 36LEDs.
Max Current: 2160mA
5V 55mA max per LED
Colour order: GRB
GPIO pin: 2
Any suggestions on how I move past this problem?
Thanks in advance.
