Outdoor RGB Floodlights - any recommendations?
Hey everyone. I’m looking to get some outdoor RGB floodlights for Halloween. Are there any which can be controlled with WLED? Open to any recommendations. Thank you.
https://yourpixelstore.com/product-category/floodlights/
:upside_down_face:
why using floodlights if some simple displays can do mutch more fun
like the eyes in the Garden fence
You can use a WEMOS D1 UNO Based Shield this is 12V and runs 150pixels WS28xx on the board
car Battery or AGM from the Recycle center will give you at least the DAY
fully Smartphone controlled
Thanks. I should have detailed that I’m in the UK so unfortunately some of those options are a no-go. I’m very envious of WLED options in the US. It’s like a desert here in the UK.
Not WLED controllable but AliExpress has some TUYA RGB floodlights that might work.
If you are running Home Assistant at home you could link to a PIR and switch when people get close.
Paul Zhang ETOP @ aliexpress: https://www.aliexpress.com/store/1103671597/pages/all-items.html?sortType=bestmatch_sort&SearchText=led+flood&shop_sortType=bestmatch_sort
Or
Rau Wu: https://www.aliexpress.com/store/1100403118/pages/all-items.html?sortType=bestmatch_sort&SearchText=led+flood&shop_sortType=bestmatch_sort
Both are the leading manufactures in China.
You could also contact Yvette Yu of Scott LED on FB: Redirecting...
Or Cici Dled from Daniel Tech’: Redirecting...
I know this is an older post but thought I should post an update regarding my previous comment.
I did buy a couple of cheap TUYA floodlights from AliExpress. They were listed as 100W but I got the following from the system:
Whilst this might add up to around 80W, unless you were using white, you only had about 10W of light useable, you may get a bit more if you are using the correct mix of colours but still not good.
Otherwise the quality was good and might be of use for the job you need, but these were returned for a refund.
