I’m putting in some under-cabinet lighting in the kitchen. There are 3 different sections that I will be lighting- one section has a 14/2 wire from a wall switch carrying mains voltage. From there, there are 14/2 wires to the other 2 sections that are otherwise not connected at all to the home power now that I have disconnected them.
My plan is to hook that switched line with mains voltage into a 5V power supply. That 5V would power my ESP8266 or ESP32 and the LED strip there, and then I plan on using the #14 wires to the other sections to carry +5VDC, GND, and the WS8212B data signal (using logic level shifters, of course).
From my estimate of how long these wires are (one goes up into the attic to clear a doorway), I think my worst-case voltage drop could be around .8 or .9 volts at full brightness (25’ estimate, worst case of 6amps), so I might have to mitigate that in wled to limit current.
Am I missing anything?
Also, since wled can only control 1 output pin, I guess I have to use the same data signal to all 3 sections, which means I could not do animations across all of the sections and each section would behave the same as the other sections.
