Question about SN74HCT245N
Good afternoon gentlemen. Thank you to everyone for your posts, creations & input. I have spent quite a bit of time reading before I ask this question. I know only enough to be dangerous regarding WLED.
My question is since the SN74HCT245N is an 8 channel level shifter, can it be used by 8 different Wemos D1 Mini Pros D4 pin (or any Node MCU for that matter) and shift them all to the proper 5V signal to 8 different LED strips? All 8 WS2812 strips would total approximately 20 meters and all items would share one power supply with all grounds tied together.
Your input is greatly appreciated.
Kind regards,
Jim
Why not use a smaller one on each?
You can also use one of the the beta branches to get multiple pins per ESP.
I would say use 74AHCT125 with ESP8266 for 4 strips or ESP32 with 74AHCT245 for 8 strips.
That’s an interesting thought. The idea behind using individual d1 minis is so that each one can be controlled either by the WLED built in patterns or addressed individually through Vixen.
In this case you need something like this SN74AHCT1G125DBVR
