RGB sliders UI setting not saved
Hi there,
I’m having an issue where, if I enable RGB sliders in the UI settings and save it, the setting is applied. But if I close the interface and reconnect after a few minutes (I am using WLED in AP mode) the sliders are gone.
WLED 0.13.3 running on nodeMCU (I have two set up and they are both having this problem). Flashed with ESPtool.
Not sure if it’s relevant but I’m connecting using an iPhone 12 running iOS 15.6.1 and I’m running a strip of SK6812 LEDs.
Many thanks, and thanks for developing this awesome software Aircookie et al.! I love using it and it has inspired a bunch of projects for me.
Kind regards,
Jimmy
These settings (under UI settings page) are stored in local browser storage not on WLED device.
This is not persistent in captive portal mode nor transferable across different mobile devices.
Try hitting “Open in browser” when captive portal opens if that will enable browser to store local settings permanently.
