Segments cycle
Hello,
I made 4 segments on my strip.
I would like to turn on each segments one by one, during 10s each, and start again after the sequence is complete. How can I do ?
If I could save each segment on one preset it would be simplier I guess.
Meanwhile, do you have an Idea ?
Yann
Maybe use Grouping to make each segment act like one LED and use Lighthouse slowed way down? Not sure if it will go that low.
Thanks Tonyno, that’s a good idea but it’s not reallydoing what i want.
For the moment, i use the effect “fade” on each segments with differents speed to light up each segments kind of randomly.
Have you got other ideas ?
Use Grouping to make each segment act like one LED and use Lighthouse slowed way down
I just tested this and it seems to work as you requested, just a bit fast still.
https://streamable.com/6ojlrl
Maybe I am not understanding?
Yes yours is working fine ! Which segments have you selected for applying effect “lighthouse” ? I tried with Only 0, or 1 to 4 selected, or 0 to 4 de selectedt, but nothing happens…
You have your segments defined incorrectly. If you want four, there can only be four. :wink:
Yes of course ! I added my 4 segments to the segment 0 … I redefined thé segments, only 4 (0,1,2 ans 3).
But I can’t obtain the same result as yours…
Do I need to select all the 4 segments or no one before select the effect ?
Sorry. I really meant one segment, but grouped…
As it says, this ends up with four, virtual LEDs.
Ah thanks it’s works !
