Hi guys,
I use this wonderful program for my effect lighting. Now I have a question which answer I have not found. I use Node RED for the automation. With Node RED I can activate a preset. Now my questions.
Can I also set the timer via remote command?
Can I activate preset cycling via remote command?
This is really easy. You’re absolutely right. The Node-Red implementation is probably incomplete. Which way is the more efficient. The HTML or the Json?
