Hello, I’ve found videos of WLED and how it works. I’m definitely intrigued. I’m new to this and have a ton of questions. Pool company just finished the job I have LED lights in the pool and outside. Unfortunately I have to use two different devices. A remote and my phone. I want to get the ESP32 chip and run the outer LED light strips.
Does anyone know if the ESP32 chip is compatible with the Solid Apollo LED lights? Or if there’s a different chip or device I can use with WLED.
Here are the specs from their site
UL Listed | UL Listed E493881 |
Dimmable | Yes |
Minimum cut | 3.94in (100mm) |
LED Color | RGB Color Changing plus White |
Color Temperature (kº) | White 6000K |
Color Rendering Index (CRI) | 80 |
Lumens Total | RGB: 1650, White: 2160 |
Total LEDs | 300 |
LEDs per Foot | 18 |
Input Voltage | 24V |
Watts per Foot | 4.4W |
Watts per Spool | 72W |
LED Type | SMD 5050 |
Beam Angle | 120º |
Warranty | 5 Years |
Weight | 1.30 lbs |
Dimensions | 16.4’ x 0.56 x 0.22 |
IP Rating | IP67 |
Product Color | White PCB |
Working Temperature | -4F to 122F |
Certificates | UL, CE, RoHS |
