Sound reactive Wled (one mcu 2 strips)
Ciao,
I would like to use two strips with one mcu and strips will work same (esp8266 node mcu lolin V3). Will there 60 LED per strip (120 totally). Is this possible ? Is there a configuration on interface of WLED ?
Recent WLED version introduced this option. The current firmware v0.13.x supports what you are looking to do. It makes it easy to assign GPIO pins, strip type, and RGB order to each individual strip. You can configure the 2 strips as 2 segments, or one long strip. You can reverse the order of one strip as well. Whatever makes sense for the way the strips are to be installed so you get the right visual effects.
Thanks for feedback. I will check when mcu artive to me.
