SunriseAndSunset via usermod2
I want add usermod UserModv2_SunRiseAndSet to my wled.
I read instruction:
Once configured, copy UserMod_SunRiseAndSet.h to the sketch file (the same folder as wled00.ino exists), and then edit “usermods_list.cpp”:
Add ‘#include “UserMod_SunRiseAndSet.h”’ in the ‘includes’ area
Add ‘usermods.add(new UserMod_SunRiseAndSet());’ in the registerUsermods() area.
I done this steps.
For checking that this mod get control i add Serial.println(“astrosetup”); to Setup section.
But i can not see string “astrosetup” at montor.(
How work Usermod API v2? Where is problem?
my WLED version 0.11.1
usermods_list.cpp:
#include "wled.h"
 * Register your v2 usermods here!
 *   (for v1 usermods using just usermod.cpp, you can ignore this file)
 * Add/uncomment your usermod filename here (and once more below)
#include "UserMod_SunRiseAndSet.h"
#include "../usermods/EXAMPLE_v2/usermod_v2_example.h"
#ifdef USERMOD_DALLASTEMPERATURE
#include "../usermods/Temperature/usermod_temperature.h"
#endif
//#include "usermod_v2_empty.h"
#ifdef USERMOD_BUZZER
#include "../usermods/buzzer/usermod_v2_buzzer.h"
#endif
#ifdef USERMOD_SENSORSTOMQTT
#include "usermod_v2_SensorsToMqtt.h"
#endif
#ifdef USERMOD_MODE_SORT
#include "../usermods/usermod_v2_mode_sort/usermod_v2_mode_sort.h"
#endif
#ifdef USERMOD_FOUR_LINE_DISLAY
#include "../usermods/usermod_v2_four_line_display/usermod_v2_four_line_display.h"
#endif
#ifdef USERMOD_ROTARY_ENCODER_UI
#include "../usermods/usermod_v2_rotary_encoder_ui/usermod_v2_rotary_encoder_ui.h"
#endif
#ifdef USERMOD_AUTO_SAVE
#include "../usermods/usermod_v2_auto_save/usermod_v2_auto_save.h"
#endif
#ifdef USERMOD_DHT
#include "../usermods/DHT/usermod_dht.h"
#endif
void registerUsermods()
   * Add your usermod class name here
usermods.add(new MyExampleUsermod());
  usermods.add(new UsermodTemperature());
#endif
//usermods.add(new UsermodRenameMe());
  usermods.add(new BuzzerUsermod());
#endif
  usermods.add(new UserMod_SensorsToMQTT());
#endif
  usermods.add(new ModeSortUsermod());
#endif
  usermods.add(new FourLineDisplayUsermod());
#endif
  usermods.add(new RotaryEncoderUIUsermod());
#endif
  usermods.add(new AutoSaveUsermod());
#endif
#ifdef USERMOD_DHT
usermods.add(new UsermodDHT());
#endif
